2013 Final release vs. 2013 Pre-release6 Connect FX
COW Forums : Autodesk Smoke
Swen Linde
on Dec 19, 2012 at 12:02:54 pm
Hello,
there is something behaving different in the final release Version of Smoke 2013 compared to the pre-release Version. When entering the connect fx menue on an empty track V2 with a clip on V1 the input (back clip) bit depth of the v1 track is set to 12 bit. (timline setting is 10bit 16fp graphic). When adding an action node the output is black. In Pre-release 6 the input (back clip) was shown at 16fp which makes sense. The Output was then converted 16fp to 10 bit. No Problems. When inserting an Resize node between the input (back clip) with output settings to 16fp everything is running fine. Is there any setting to avoid this?
Thanks an best regards
Swen
Brian Mulligan
Re: 2013 Final release vs. 2013 Pre-release6 Connect FX
on Dec 22, 2012 at 11:44:54 pm
Yes. This is a bug in the Release. Add a RGB Lut or Resize and bump your BACK CLIP to 16 bit and all should be good.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Swen Linde
on Dec 31, 2012 at 2:26:49 pm
Thank you Brian. That was my thought too. Happy new Year.
