fail to open project
COW Forums : Autodesk Smoke
andi no
on Nov 15, 2012 at 2:27:49 am
I use pr5, when i was working a project suddenly the smoke got crashed and it freeze the OS. So i restart the os , but since then, the project can not be open anymore, when loading that project, it will always crash when it's loading the clips (status -> EDITDESK : loading clips). Fyi smoke will load normally if i load another project or new one.
This is only test project, but in case this is a real project then it will be a disaster. So, in this case, what the solution ? can the project be recovered ? any idea to anticipate this in future ? any simple and handy backuping system ? i'm thinking of creating a new project and re-import (transfer) the clips from the fail (or offline) project , but this feature seems not to be available yet, am i right?
Grant Kay
Re: fail to open project
on Nov 15, 2012 at 12:24:35 pm
If the project crashes and failed to open, I can assume that the desktop is corrupt.
What you can do in this case is open a new project and attempt to transfer the clips from the old project to the new one and hopefully it will work.
If that fails I would contact Autodesk support and see if the engineers can help you find a technical way to save your files if possible.
Check out the Smoke Learning Channel
Youtube -
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
© 2018 All Rights Reserved
