2013 and 2012 on same computer
COW Forums : Autodesk Smoke
Adam Corey
on Sep 6, 2012 at 4:32:59 pm
Are there any issues with installing Pre Release 3 on the same box that is currently running 2012 SAP2? . I've been playing with 2013 on a 2 year old imac but would like to see how it performs on better spec. computer.
Adam Corey
DC Collective
Design - Edit - Create
http://www.dccollective.tv
Brian Mulligan
Re: 2013 and 2012 on same computer
on Sep 6, 2012 at 5:14:48 pm
There are. All of the background process will get updated to the 2013 versions. This may cause issues with 2012 with wiretap/backburner.
If you can do a 2nd OS partition or something, that would be the safest way. Or if you don't have any projects you need in 2012, you can always uninstall everything to get 2012 back to normal after you test 2013.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
