Adding Pulldown
COW Forums : Autodesk Smoke
Aaron Barton
Adding Pulldown
on Aug 30, 2012 at 2:41:30 pm
Hey Everyone,
So I'm wanting to add pulldown to my 23.98 conform in Smoke, and I was wondering how to control the pulldown cadence and field dominance. The problem I'm running into is that so far, when I used the pulldown tool, my 2-pop gets extended into one of the fields on the Next frame.
David Jahns
Re: Adding Pulldown
on Sep 1, 2012 at 4:53:36 pm
How the pull down is added actually depends on which frame you are parked on when you click it. Try parking on a +01 frame. This should make :02 become the first jitter frame.
David Jahns
Joint Editorial
Portland, OR
