Gmask
COW Forums : Autodesk Smoke
Aaron Barton
Gmask
on Aug 24, 2012 at 5:54:04 pm
Hey everybody,
So I'm in Connect FX and I wanted to use a black solid and a gmask node to create a vignette, but when I start drawing a mask my output turns black and white. Is there a way to correct this?
Brian Mulligan
Re: Gmask
on Aug 24, 2012 at 5:56:48 pm
Can you post a pic of your schematic? Try adding a color frame node into the matte input of your gmask.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Aaron Barton
Re: Gmask
on Aug 24, 2012 at 6:43:04 pm
Brian Mulligan
Re: Gmask
on Aug 24, 2012 at 6:49:33 pm
Yes.. Add a white color frame node to the Blue matte input of the Gmask.
Create your mask...
Then you can feed the output (yellow) of the Gmask into something to composite with your Color correct nodes. a Blend & Comp node would be the easiest.
Blend & Comp Node:
Input 1= Black frame
Matte 1=Gmask output
Green Background=Output form last Color Correct Node.
Adjust transparency or blend modes
Brian Mulligan
Twitter: @bkmeditor
Aaron Barton
Re: Gmask
on Aug 24, 2012 at 7:16:36 pm
It worked! Thanks Brian
Brian Mulligan
Re: Gmask
on Aug 24, 2012 at 7:20:46 pm
There are of course about 20 different ways you can achieve the same Vignette in Smoke 2013. But you are on the right track. :)
Brian Mulligan
Twitter: @bkmeditor
