Laying off to tape
COW Forums : Autodesk Smoke
Aaron Barton
Laying off to tape
on Aug 14, 2012 at 7:54:42 pm
Hey guys,
I was wondering if anyone has successfully laid off from tape.
I've been trying but I keep getting an error message that reads "Every Clip was Discarded: Max Depth:1"
I know the VTR is working because I was able to capture in Smoke.
Any ideas?
Robert Adam
Re: Laying off to tape
on Aug 14, 2012 at 8:28:10 pm
Hi Aaron.
here's what I have replied to your AREA thread:
Are you using the correct AJA driver? We recommend 10.3 for Lion and 10.3.1 for Snow Leopard.
What project resolution and timing are you using? Try a NTFS proj. and see if that works.
Regards,
Robert.
Autodesk M&E Support
http://www.facebook.com/AutodeskMECF
Aaron Barton
on Aug 15, 2012 at 2:18:16 pm
Hey Robert,
Thanks for the suggestions. I've successfully laid off an NTFS Project to Digibeta!
I'm going to double check my settings in the Smoke Setup regarding my HDCAM-SR Deck and make sure everything is set correctly.
Thanks again.
