Versioning in Smoke 2013 - Mac
COW Forums : Autodesk Smoke
Craig Harris
on Jul 31, 2012 at 5:35:44 pm
I am trying to do a 23.98 - PAL conversion in the latest trial release of SOM 2013.
My method has always been to create a PAL colour source and insert that into a new sequence. That works fine and my sequence is set up as PAL.
When I insert my 23.98 material into the sequence, I still get the warning (inserting 23.98 into a 25 sequence) but there doesn't appear to be a Timewarp applied to the footage. When I render / playback the material looks smooth but jumps a few frames every 2-3 seconds.
Is this a beta issue?
Craig
Ken LaRue
Re: Versioning in Smoke 2013 - Mac
on Jul 31, 2012 at 10:27:13 pm
Hi Craig,
I'm trying to reproduce this and I can't. Is this in Pre-Release 1 or 2? Do this as a test. First duplicate the video in the media library, this way you have a clean untouched file and then right click on the new duplicated video file and choose Open as Sequence. Then check the format of the new sequence. Does that work correctly?
Ken LaRue
Autodesk Smoke Technical Marketing Manager
