Anyway to select all in timeline?
COW Forums : Autodesk Smoke
Jeremy Garchow
on Jun 30, 2012 at 4:08:53 am
Everytme I select all, it selects the whole media library.
Dave Boampong
Re: Anyway to select all in timeline?
on Jun 30, 2012 at 5:23:52 pm
Using the Smoke Classic keyboard shortcuts hitting the / key on the numeric pad should select everything in the timeline. Is that what you are looking for?
Jeremy Garchow
on Jun 30, 2012 at 11:19:16 pm
Thanks.
I was using fcp7 presets but I'll give it a shot. At least I know it's possible.
Jeremy
Dave Boampong
on Jul 1, 2012 at 6:39:24 am
Shift + Command + A
To deselect press * on the numeric pad
Jeremy Garchow
on Jul 2, 2012 at 1:38:24 pm
Shift!
Thanks so much, Dave.
Jeremy
chris gernon
on Aug 6, 2012 at 2:51:21 am
You can also tap the track headers (same area where the mute/lock buttons are).. and select everything in the track.. I think you can select and deselect the same way.. it's also good if you lasso around a group of clips in a timeline.. then you can deselect the tracks you don't want by clicking on the tracks.
