Export with Alpha (Matte)
COW Forums : Autodesk Smoke
Sean Cole
on Jun 28, 2012 at 4:06:48 pm
Hi all,
Just getting to grips with Smoke2013. Bit of a mind shift from previous versions. How do I export a clip with Alpha?
I've created a CFX with an Action. No BG clip, just one foreground with a MasterKeyer. 2Outputs from the Action (1 Comp, 2 Media Matte) to the inputs of the CFX node. Both Action outputs set to 'All Objects'. I am trying to Export to Prores4444 with the Matte set to the alpha channel. With the clip on the timeline also it has a black background rather than showing the clip underneath.
Hope you can help
Sean
robert coulin
Re: Export with Alpha (Matte)
on Jul 2, 2012 at 8:01:00 pm
hi,
looks like it says in the notes, that RGBA can only be exported from a matte container - currently i hope ...
hth
robert
robert coulin
http://www.dreamwalks.com
Brian Mulligan
on Jul 2, 2012 at 8:03:18 pm
If that's true, then you could create the CFX and use the Commit CFX option (in the gear, i think) which will create the matte container.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
