Hey Grant - Key Master K question,
COW Forums : Autodesk Smoke
Brooks Tomlinson
on Jun 21, 2012 at 2:53:11 pm
Hi Grant!
I have a question, in the "Timeline FX: Axis -- Keying" at time marker 2:54 you add range to your patch by holding command and clicking and dragging, a nice box shows what you want to add to the patch. I have tried on several different computers now (imac, macbook pro) with and without a tablet, and I can not get a box to show up.
It just goes to the color picker, and I have to click alot to get anything done. It is not a nice drag box like you have.
I'm on the FCP hot keys. I know it is most likely a peb-kac error. But I was wondering if you could help me with what i'm doing wrong.
Brooks
"I dream in 32bit float, don't you?"
Brooks Tomlinson
Brian Mulligan
Re: Hey Grant - Key Master K question,
on Jun 21, 2012 at 2:57:35 pm
Try CTL+Drag or SHIFT+CTL+Drag
On my MBP with small keyboard it's CTL+Drag.
You are not the first with this issue.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Grant Kay
on Jun 21, 2012 at 3:08:13 pm
Hi Brooks,
It's SHIFT+CONTROL+DRAG .... If the video is wrong than it's possible they changed the shortcuts just after I made the video..
Thanks for the feedback.
Regards
Grant
Check out my Smoke blog at http://area.autodesk.com/blogs/discreetuk
Subscribe to my YouTube Channel - SMOKEHOWTOS
Follow me on Twitter - http://www.twitter.com/discreetuk
Brooks Tomlinson
on Jun 21, 2012 at 4:00:59 pm
Thanks Brian and Grant!
It was a peb-Kac error :) (problem exists between keyboard and chair) the shift-control click worked. I have found the wiki of keyboard short cuts. and that helps.
Thanks again
Brooks
Brooks Tomlinson
