Tint Effect in Smoke?
COW Forums : Autodesk Smoke
Aaron Barton
on Jan 14, 2013 at 4:44:12 pm
Hey everyone,
So I have a shot that I need to change the color of an actor's hair from red to a dark brown. I did a test in After Effects and I was able to do this by duplicating the layer, adding the tint effect and applying a blending mode.
How would I go about doing this in Smoke?
Grant Kay
Re: Tint Effect in Smoke?
on Jan 15, 2013 at 9:31:33 am
Hi Aaron,
You have two ways to approach it in Smoke.
You can either just use layers in the sequence to "mimic" what AE is doing. So duplicate your video layer, colour correct it and blend it. You might need to Roto if required.
Or you can select the single layer, go into CFX. Use the colour correction nodes to grade the hair as you want. Than you can use a blend & comp node to Logic ops node to blend the two layers back together again. As before, you can use a Gmask node to root areas if needed.
Check out the Smoke Learning Channel
Youtube -
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
© 2018 All Rights Reserved
