Smoke and AJA
COW Forums : Autodesk Smoke
Greg Jones
Smoke and AJA
on Jun 14, 2012 at 1:27:52 pm
It was a little confusing reading the release notes. Does Smoke 2013 support video output via AJA? I have an AJA Kona 3 and it clicks on when opening Smoke, but it doesn't sync up, so no video. Anyone else have this happen?
Greg Jones
D7,Inc.
Orlando,FL.
http://www.d7-inc.com
Frederic Warren
Re: Smoke and AJA
on Jun 14, 2012 at 1:31:31 pm
Smoke does usually support Video I/O through AJA, but the functionality is not enabled in the Pre-Release trial 1.
It will be back in a future Pre-Release trial.
fred
Frédéric Warren
Flame / Smoke Senior User Experience Designer
Autodesk Media & Entertainment
Jeremy Garchow
Re: Smoke and AJA
on Jun 14, 2012 at 2:28:47 pm
[Frederic Warren] "Smoke does usually support Video I/O through AJA, but the functionality is not enabled in the Pre-Release trial 1."
Hmm. Weird. It works for me. I love that you can click the "Monitor" button in connectFX to get either the fx tree or video on the monitor.
Running v10.3.1 Kona drivers on OS 10.7.4
Jeremy
Ben Rojas
Re: Smoke and AJA
on Jun 14, 2012 at 2:52:34 pm
Jeremy, are you running 2012 as well? Maybe it's enabled for Smoke owners? I'll know soon enough as I'm DL'ing SP2 and updating the Kona drivers. 2013 is up and running at home but I was concerned putting it on SMACK at work... Looks like other folks are doing it so let the adventure begin!
Should be a fun summer, ay ;o)
Ben Rojas
Editor|Artist|Dir. of Post Production
KSC KREATE
3850 N 28th Ter. Ste. 101
Hollywood, FL. 33020
P. 954.326.7600
F. 954.326.7766
C. 305.301.2771
E. ben.rojas@ksckreate.com
http://www.ksckreate.com
Jeremy Garchow
Re: Smoke and AJA
on Jun 14, 2012 at 4:30:53 pm
[Ben Rojas] "Jeremy, are you running 2012 as well? Maybe it's enabled for Smoke owners?"
Nope, Smoke noob here.
I read that video monitor out was enabled, but capture/deck control out was not enabled.
Jeremy
Ben Rojas
Re: Smoke and AJA
on Jun 14, 2012 at 6:09:17 pm
ah, ok, was ready to fire away questions on how your sys was working because I just heard through the grapevine that putting 2013 on the same sys w/2012 will 'cause problems. Guess I'll continue evaluating 2013 at home and keep 2012 running smoothly.
Ben Rojas
KSC KREATE
P. 954.326.7600
F. 954.326.7766
C. 305.301.2771
Greg Jones
Re: Smoke and AJA
on Jun 14, 2012 at 6:39:47 pm
I just realized my Aja is working fine through sdi, just not component. My reference monitor is component, which does not have a signal, and my plasma, which is sdi, does have a signal.
Weird
Greg
Jeremy Garchow
Re: Smoke and AJA
on Jun 14, 2012 at 7:09:31 pm
[Greg Jones] "I just realized my Aja is working fine through sdi, just not component. My reference monitor is component, which does not have a signal, and my plasma, which is sdi, does have a signal."
I think that's correct. Smoke is all digi-tahl.
Loius Martin
Re: Smoke and AJA
on Jun 15, 2012 at 2:49:29 pm
Just to clarify ,
Smoke pre_release 1 has broadcast monitor support trough AJA kona 3 / 3G and ioXt devices. All you need is driver 10.3.1 from AJA.
What Frederic meant was , the capture/output to VTR is not yet available in preview 1.
you can also broadcast on a Dual monitor setup , if your Mac OS detects one ,DVI , HDMI ..etc
Louis
David Jahns
Re: Smoke and AJA
on Jun 15, 2012 at 12:57:10 pm
What probs have you heard about with 12/13 on same sys? I have an alt boot drive for 13, and also using a different media storage drive. Should be ok in that setup, right?
David Jahns
Joint Editorial
Portland, OR
Bret Williams
Re: Smoke and AJA
on Jun 15, 2012 at 5:55:13 pm
Are there plans to support BMD devices?
Juan Salvo
Re: Smoke and AJA
on Jun 15, 2012 at 6:01:28 pm
Already been asked and answered a couple of times on this forum.
Online Editor | Colorist | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
