backburner manager
COW Forums : Autodesk Smoke
simon brewster
backburner manager
on Jun 13, 2012 at 11:34:20 pm
hi can anyone help with this one
when importing a file through media hub i get a error message saying cannot connect to back burner manager on port 1
thanks
s
Brian Mulligan
Re: backburner manager
on Jun 13, 2012 at 11:46:41 pm
I am guessing that you are trying to "create project media" or you have proxies enabled for the project or both.
Backburner is a bit buggy in Pre1 but you should still be able to send a job to it, it just that it doesn't process.
Open the Service Monitor in the Autodesk/Utilities folder. Are all the light green? If not Restart Backburn Manager and Server. Even if they are Green... restart them. Then try and import again.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
simon brewster
on Jun 14, 2012 at 12:29:59 am
hi yes all green but i guess if it does not work then any media in smoke 2013 is just running from its source location and not from smokes storage media drive? renders though i guess are on smokes own storage
s
Brian Mulligan
on Jun 14, 2012 at 12:36:25 am
Correct.. but you should still have been able to send a job.. you shouldn't have had that error. A reboot of mac might also help.
Brian Mulligan
Twitter: @bkmeditor
Tero Ahlfors
More backburning questions
on Jun 14, 2012 at 6:18:51 am
I can import but when I try to export the exported clip just goes to wait into the backburner queue and does nothing. I don't have a backburner set up.
robert coulin
Re: More backburning questions
on Jun 14, 2012 at 12:21:00 pm
hi,
well - as you mention:
.... goes to wait into the backburner queue and does nothing. I don't have a backburner set up. ....
obviously you need to have backburner running, unless you export directly in the foreground (& wait till its done)
robert coulin
http://www.dreamwalks.com
Tero Ahlfors
on Jun 14, 2012 at 7:59:26 pm
I have zero idea how to set up a backburner thingamajig and also no idea how to export directly.
