a couple of questions
COW Forums : Autodesk Smoke
simon brewster
on Jun 5, 2012 at 11:07:36 pm
hello can anyone answer these questions?
can anyone tell me if the connect fx is compatible with flame /flare? ( please put flare on a mac!)
can smoke 2013 conform .edl with frame rate convert etc?
does the thumbnail layout still exist? ... a tab?
how about a lustre node? not the whole app.... just a clip by clip or adjustment layer where we can have access to up to date tools ... the editor can then set up a look that can be followed through in post quickly and professionally
try smoke with a dvi out it will change the experience.... it is much much better than a single screen
so before you try 2013 set up your dvi out to a second hd monitor
thanks
simon brewster
Brian Mulligan
Re: a couple of questions
on Jun 6, 2012 at 12:25:56 pm
[simon brewster] "can anyone tell me if the connect fx is compatible with flame /flare? ( please put flare on a mac!)
how about a lustre node? not the whole app.... just a clip by clip or adjustment layer where we can have access to up to date tools ... the editor can then set up a look that can be followed through in post quickly and professionally "
The Nodes are the same, so setups will be interchangeable.
Conform is being redeveloped over the Pre-releases
Thumbnail still exists with improved organization (clean up/fit all) T is the shortcut
Many people ask about a Lustre node... I have never seen one.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
simon brewster
on Jun 6, 2012 at 10:32:33 pm
thanks Brian
i guess the lustre node would be the same idea as a baselight plugin for avid/nuke etc ... maybe baselight will make a spark : )
s
