Smoke QT caching issue
COW Forums : Autodesk Smoke
Patrick Miller
on Sep 27, 2013 at 12:57:12 am
Newbie question: Trying to export ProRes QTs out of Smoke. Because I'm new to the program I've been doing a lot of compression and settings tests. I've been trashing my old exports, but if I try to export the same sequence with a different setting Smoke will show that the file has exported, but the movie won't open. If i set the destination to a different folder it exports fine. I'm assuming this means its a caching issue. Is there any way to fix this? A way to clear the cache of my exported files?
Grant Kay
Re: Smoke QT caching issue
on Oct 8, 2013 at 8:54:19 am
Strange, Smoke should prompt you to over-write the old file like any other software.
Have you tried restarting Smoke and created a new user before trying again?
Check out the Smoke Learning Channel
Youtube -
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
© 2018 All Rights Reserved
