Rendering/Working with SoftFX in Timeline
COW Forums : Autodesk Smoke
harrison Schaaf
on Aug 17, 2013 at 4:50:02 am
Hi All,
I'm working in Smoke 2013, and client wants to be able to see 2:35 letterbox on all of the shots in the sequence, and turn it off and on at will...codec is 1920x1080p footage from Maya, stored locally on a Pegasus Promise.
My solution was to simply layer an empty clip with a softFX letterbox effect on top of my sequence, but Smoke requires a re-render for many of the edits I need to perform - is there a way I can force Smoke to push out a RAM preview, or so I can edit and view without rendering?
Feel like Smoke and my machine definitely have the power to accomplish this with such a simple effect - any ideas?
harrison
Joel Osis
Re: Rendering/Working with SoftFX in Timeline
on Aug 17, 2013 at 8:37:18 am
while in the player click on the options dropdown on the right change it to overlays and in the letterbox dropdown change it there, no render required
w: http://www.joelosis.com
e info@joelosis.com
