Adjusting 3D Convergence in Smoke 2013
COW Forums : Autodesk Smoke
harrison Schaaf
on Aug 12, 2013 at 12:20:03 pm
Hi All,
Working with stereo material in Smoke 2013, and I need to adjust convergence on a clip-by-clip basis once a rough edit with stereo clips has been completed.
Creating and editing stereo clips with Smoke's utilities/tools is no problem, however all documentation that I can find on convergence and other 3D tasks seems like it only pertains to earlier versions of Smoke. I saw one older demo where you could adjust convergence with Axis as a soft effect, but I have had no luck in Smoke 2013 after an hour of poring through the menus.
Can anybody enlighten me?
Many thanks in advance -
Harrison
Grant Kay
Re: Adjusting 3D Convergence in Smoke 2013
on Aug 13, 2013 at 11:02:43 am
Hi Harrison,
The functionality is still there.
Add an Axis to your stereo clip.
In the mini UI, you need to change the pull-down from SURFACE to STEREO. This will show the convergence control that you are after.
That should do it.
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
harrison Schaaf
on Aug 17, 2013 at 3:41:23 am
Grant for the win every time. Thanks man.
