smoke advanced 2012 uprez workflow
COW Forums : Autodesk Smoke
Marino Di Napoli
on May 30, 2013 at 8:33:17 pm
At one time, I would capture & edit in SD, and after approvals, I would recapture the timeline in HD.
That workflow doesn't seem to work any more.
I created a record clip {timeline} with 6 audio tracks + 4 video layers. Save it to the library, copy the clip, unlink everything, consolidate to 30 frame handles, reformat to HD, and then recapture. When I select recapture, the EDL list has 4 items labelled "VIRTUAL", with SRC TC of 00. Place this clip on a a timeline, do an ALT+CLICK, and all SRC TC are accurate.
The SD project is NTSC 29.97df.
The reformatted clip is 1920x1080 29.97df.
How do I recapture this timeline in HD?
Grant Kay
Re: smoke advanced 2012 uprez workflow
on May 31, 2013 at 9:29:10 am
What version of Smoke are you using?
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
Marino Di Napoli
on May 31, 2013 at 3:17:58 pm
Smoke 2012 Ext1 SP1
Grant Kay
on May 31, 2013 at 6:19:57 pm
ok, so even with an unlinked timeline, you went back to RECAPTURE and you just get 4 clips with virtual sources.
What if you where to match out the sources from the timeline and tried to recapture them again? Does the timecode appear? You can then relink them back into the timeline.
Sorry, been working on 2013 so trying to recall the steps from memory.
Regards
Grant
Marino Di Napoli
on Jun 3, 2013 at 2:27:20 pm
Taking the unlinked timeline to the Record area, all TC are present.
Select Recapture, and the TC appear in the list.
So, I could take the unlinked timeline, match everything out to the source area, save that source area, and recapture each clip. Once everything is recaptured, I should be able to select the unlinked record clip, and select Relink - From Reel. That should rebuild the timeline.
