smoke 2013 on mac and mxf files
COW Forums : Autodesk Smoke
cliff armstrong
on Mar 28, 2013 at 4:16:36 pm
does smoke 2013 on mac work with, import, export, and realtime playback mxf files? your thoughts.
Grant Kay
Re: smoke 2013 on mac and mxf files
on Mar 28, 2013 at 5:43:13 pm
Hi
MXFs should import and export and playback in Smoke.
The only catch is to check that the codec in the MXF is compatible with Smoke.
Where do the MXFs come from?
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
cliff armstrong
on Mar 28, 2013 at 9:34:33 pm
thanks Grant! your the best. the mxf files would be transcoded from avid symphony uncompressed 10bit 4:2:2 maybe 4:4:4 arri pro res files. and does smoke work best with these mxf or a particular mxf codec?
thanks again!!
Grant Kay
on Mar 29, 2013 at 9:17:56 am
Hi Cliff
You can work directly withe the Alexa ProRes QuickTime files or Avid DNxHD MXFs.
I don't think we support uncompressed MXFs or transcoded ProRes MXFs.
Hope this helps.
Regards
Grant
bela smith
on Apr 18, 2013 at 4:54:38 pm
Yes smoke 2013 on mac work with, import, export, and realtime playback.
