Where are the 2012 Smoke tutorial install on Mac?
COW Forums : Autodesk Smoke
Stanley Little
on Nov 12, 2012 at 6:25:16 am
I'm trying to locate the Gladiator footage that was install when I install Smoke 2012 can some tell me the location.
Thanks.
Grant Kay
Re: Where are the 2012 Smoke tutorial install on Mac?
on Nov 12, 2012 at 10:28:01 am
The footage will be stored in the Project/images folder on your system disk.
So if you open a go to command SHIFT+COMMAND+G and type: /usr/discreet/project//images
NOTE: must be replaced by the name of the tutorials project.
Inside the images folder you should find all the JPG sequences with the footage you are after.
Regards
Grant
Check out the Smoke Learning Channel
Youtube - http://www.youtube.com/smokehowtos
or search for the Smoke Learning Channel on iTunes
Follow me on twitter @discreetuk
Eli Beck-Gifford
on Aug 15, 2013 at 9:39:27 pm
I installed the 2012 tutorials too. Used your command :SHIFT+COMMAND+G and type: /usr/discreet/project//images
Didn't find anything. When i try to install it again it says it's already been installed. Any idea on where else this could live?
Brian Mulligan
on Aug 15, 2013 at 9:56:58 pm
If you just go to... /usr/discreet/project/
Look for a project called tutorial or something. Then look in the images folder in that project folder. I know there was a bug on some systems where the tutorial project wouldn't install. However your path posted needs a project name in it.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
