Prores 24 bit Audio Codec good for Export to FCP 7?
COW Forums : Autodesk Smoke
Barry Liu
on Jul 14, 2012 at 5:36:59 pm
Hello!
I am struggling to find a good audio codec to export for FCP 7.
I tried exporting Linear PCM 24 Bit Little Endian.
However, when I drag that prores file into FCP 7 it says there are errors with it and must be recaptured, it then plays in the wrong frame rate in Final Cut Pro.
Any suggestions for a good prores audio codec that’ll play fine in FCP 7? I really would like to output 24 bit instead of 16 bit.
Brian Mulligan suggested to output in SOWT audio codec but that is 16 bit unfortunately.
