Integrity Check Failing for 7 days error
COW Forums : Autodesk Smoke
Stanley Little
on Jul 10, 2012 at 4:07:05 am
Im getting a integrity fail message at start up. How can I correct this error message.
Thanks.
Robert Adam
Re: Integrity Check Failing for 7 days error
on Jul 10, 2012 at 3:21:14 pm
Hi Stanley.
This means that vic (the Volume Integrity Check utility) was unable to run.
To find what caused vic to crash, open a Terminal and take a look at the vic log. Type this command:
cat /usr/discreet/log/vic.log
hope this helps,
Robert.
Autodesk M&E Support
http://www.facebook.com/AutodeskMECF
Stanley Little
on Jul 10, 2012 at 5:24:42 pm
No that didn't help at all. No such file or directory was the message I got back.
Robert Adam
on Jul 10, 2012 at 5:28:38 pm
That means vic didn't even get to create its log file.
Let's try to troubleshoot this by looking at the two main causes of vic errors: leftover project lock files or incompatible libraries.
-> Did smoke crash or did you force it to exit last time you've used it? Did any other workstations on your network remotely open a project from this smoke machine?
-> Do you have more than one version of Smoke running on your computer? Did you get this error when trying to open the older version?
Regards,
Robert.
Stanley Little
on Jul 10, 2012 at 5:44:10 pm
It all got wacky when I install the 2013 demo on my system, I no longer have 2013 then I reinstall 2012 and still getting the error.
moody glasgow
on Jul 10, 2012 at 5:58:31 pm
It is most likely seeing the project and/or media from Smoke2013. It cant access them anymore, so it will give you that error messsage.
moody glasgow
smoke/flame
http://www.thereelthinginc.com
Robert Adam
on Jul 10, 2012 at 6:00:40 pm
Ok, it makes sense now. I imagine you've created projects in Smoke 2013 that vic now finds and complains about.
Perform these tasks to delete the smoke 2013 projects:
1. Open the Terminal app from the Applications > Utilities folder.
2. Type the following command:
/usr/discreet/io/2013.1.alpha6/bin/cmtool
3. The prompt should have changed to "cmtool>". Type the following command:
open volume stonefs7
4. Type the following command to get the list of projects:
ls
5. Now repeat the following command for every project you have created in Smoke 2013 (replace [name] with the actual name):
delete project [name]
6. When you're done, type the following command to exit cmtool:
quit
7. Close the Terminal and try running Smoke again.
Hope this works!
Robert.
Stanley Little
on Jul 10, 2012 at 6:11:39 pm
Thanks so much, I'll try it tonight when I get in.
Stanley Little
on Jul 11, 2012 at 4:17:30 pm
What I had to do was right click on the Smoke icon (Show Content) then from the Discreet folder I deleted all of the 2013 projects and folders. Problem solved.
Thanks Again.
