XDCam
COW Forums : Autodesk Smoke
Alan Maiden
XDCam
on Jul 3, 2012 at 9:35:30 am
I have a job coming up that needs to be laid off to XDCAM. I have never used this format before and there doesn't seem to be an XDCAM configuration in the vtr setup of the smoke on mac. Has anyone used XDCAM as an output vtr from a smoke on mac that could enlighten me on anything that I could/should do.
Cheers
Brian Mulligan
Re: XDCam
on Jul 3, 2012 at 11:56:23 am
I would do some tests, but I would think that you could use the standard Sony HDCAM configs. We had D2 at the station and it worked fine with BVW75 settings. Sony is pretty good about being consistent.
But again, I would test.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Alan Maiden
Re: XDCam
on Jul 3, 2012 at 3:55:17 pm
Thanks Brian. Was planning to test when everything was set up, just thought someone might have had some experience. But I understand where you're coming from with standard Sony config, will give it a go first.
Cheers
