Conforming a RED edl?
COW Forums : Autodesk Smoke
Greg Rubin
on Jun 22, 2012 at 5:43:54 pm
Hi all, to start Im working on Smoke 2011 Ext1 SP3. I am conforming a short film in the Smoke. I have loaded all of the files from the EDL using Wiretap and have all of them in my library. Do you know how to assemble the EDLs in the Smoke now that I have all the footage loaded? It isnt seeing it the way it does when you load from tape. Any information would be very helpful!
Grant Kay
Re: Conforming a RED edl?
on Jun 27, 2012 at 9:38:16 am
Hi Greg,
In Smoke 2011, I would place all your media into one reel in the clip library.
Go to the video IO menu and choose IMPORT EDL. Load your EDL.
In the module, you should be able to select the target reel in the clip library. If everything all matches up than you should be able to assemble the programme.
Hope this helps.
Regards
Grant
Check out my Smoke blog at http://area.autodesk.com/blogs/discreetuk
Subscribe to my YouTube Channel - SMOKEHOWTOS
Follow me on Twitter - http://www.twitter.com/discreetuk
