Cyrillic symbols / fonts in Smoke - How to?
COW Forums : Autodesk Smoke
Pavel Pavlov
on May 10, 2012 at 2:01:12 pm
Hi!
Can I use Cyrillic (Russian) language to name clips or folders in Smoke? If I try to write on Russian - I don't see any symbols.
And how can I write Russian title in my projects?
Thanks.
Pavel Pavlov
Editor, Air Promo
TNT-Broadcasting Network
Moscow, Russia
robert coulin
Re: Cyrillic symbols / fonts in Smoke - How to?
on May 10, 2012 at 3:02:31 pm
hi,
you would need a font with all the characters (obviously)
by default, all encodings should be activated in the init.cfg (smoke config > manual edit - almost at the end)
maybe the best way is to import a .txt file with the text, as this has all the necessary characters (ascii codes) entered ...
good luck
robert
robert coulin
http://www.dreamwalks.com
Robert Adam
on May 10, 2012 at 3:49:33 pm
Hi Pavel.
Try the instructions in the following Knowledge Base article: http://usa.autodesk.com/getdoc/id=TS17520520
Let me know if that worked.
Regards,
Robert.
Autodesk M&E Support
http://www.facebook.com/AutodeskMECF
Pavel Pavlov
on May 10, 2012 at 6:25:10 pm
Robert it's working!
Thank you!
It is solution for title and text.
I choose right font only!
And how about Russian name folders, clips and comments? Is it possible?
Pavel Pavlov
Editor, Air Promo
Moscow, Russia
Robert Adam
on May 10, 2012 at 7:02:11 pm
Hi Pavel.
Unfortunately, non-latin characters are NOT supported for project names, clip names, etc.
There are no plans to implement support for this in the near future.
Regards,
Robert.
Pavel Pavlov
on May 11, 2012 at 6:13:56 am
It's not a big problem.
Thanks for answer, Robert!
Pavel Pavlov
Editor, Air Promo
Moscow, Russia
Robert Adam
on May 11, 2012 at 12:27:22 pm
My pleasure.
Regards,
Robert.
