vic: command not found
COW Forums : Autodesk Smoke
Dave Boampong
on Apr 19, 2012 at 8:15:03 am
I run the vic -v stonefs7 -p command in a terminal and got the message -bash: vic: command not found.
Dave
Robert Adam
Re: vic: command not found
on Apr 19, 2012 at 12:29:57 pm
Hi Dave.
Try entering the full path of vic: /usr/discreet/io/bin/vic
Here's a KB article that provides more information on using vic:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15492957&l...
Regards,
Robert.
Autodesk M&E Support
http://www.facebook.com/AutodeskMECF
Dave Boampong
on Apr 19, 2012 at 2:11:30 pm
Thanks Robert,
The hard drive is just filling up. On a 3 minute piece I started with 850G free space. I then chose to add proxies and after processing the free space came down to about 250G. After processing changes etc. it is now at about 100G. I need to free up space. I will try your suggestion.
Regards
Dave
