Move Editdesk Panel to the right
COW Forums : Autodesk Smoke
Dave Boampong
on Apr 3, 2012 at 7:52:32 am
Guys how does one move the Editdesk Panel to the right?
Dave
Frederic Warren
Re: Move Editdesk Panel to the right
on Apr 3, 2012 at 10:15:48 am
You have to hold down the Ctrl key on the left side of the keyboard and hit the Swipe Bar on the right side.
fred
Frédéric Warren
Product Designer - Creative Finishing
Autodesk Media & Entertainment
Dave Boampong
on Apr 3, 2012 at 10:50:06 am
This is cool. Thanks.
Pavel Pavlov
on Apr 3, 2012 at 10:17:19 am
Hi! It is from manual :)
The EditDesk list appears on the left or right side of the Source Area. You can modify the display of the EditDesk list and set the side of the screen on which you want it to appear:
•To toggle the visibility of the EditDesk list, press Ctrl and swipe the side of the screen.
•To switch the EditDesk list sides, press Ctrl and swipe the side of the screen opposite the EditDesk list.
•To have the EditDesk list occupy the entire Source Area, press Shift+L or select List in the Source Area Layout box.
Aaron Neitz
On a tangent....
on Apr 4, 2012 at 9:54:26 pm
Has anyone figured out how to resize the name field in the editdesk panel?
In the expanded list view you can resize all the fields (TC in, TC out, comments, etc...) but not the field with the name of the element.
I've played around fruitlessly with control+alt+f9 to try and expand it.... nope.
Frederic Warren
Re: On a tangent....
on Apr 4, 2012 at 10:52:17 pm
Unfortunately, it is not possible to resize the name field.
As a "workaround" you can hold down the ALT key on the left side of the keyboard to call up the Clip Information box in which you can see more characters for the name.
fred
Frédéric Warren
