How to select e.g. half the timeline?
COW Forums : Autodesk Smoke
Corinna Canek
on Apr 2, 2012 at 1:30:16 pm
HI,
what I mean is, I have a timeline with about 10 layers and a bunch of clips and dissolves etc. Now I have to TW a clip somewhere in the middle, so I have to move everything over to the right, so I can extend or shorten that clip.
Is there a different way to select everything than 'drawing a box' from the right of the last clip? Cause I never catch everything (especially, when I don't see all the layers at once).... I need something like in Final Cut, where you can select everything that's to the right of the timeline cursor.
Thanks!!
Brian Mulligan
Re: How to select e.g. half the timeline?
on Apr 2, 2012 at 4:03:03 pm
SHIFT + F5 will give you the large timeline view, which might help make things easier to lasso with the box.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Brian Mulligan
on Apr 2, 2012 at 4:07:43 pm
SHIFT and drag the positioner will highlight everything as it passes.
Brian Mulligan
Twitter: @bkmeditor
robert coulin
on Apr 2, 2012 at 7:46:10 pm
hi,
not sure, if this is, what you want - but just TW lock both - ripple trim with sync on & link cuts off (if you need to insert gaps) should give you that in one pass ... ?
robert
robert coulin
http://www.dreamwalks.com
