WireTap Central - not exporting h264 quicktimes
COW Forums : Autodesk Smoke
David Jahns
on Mar 13, 2012 at 7:24:17 pm
I'm having issues with WTC not creating quicktimes.
It seems to do fine creating DV, MPEG-4, or iPhone files etc, but whenever I choose H264 (Main) or H264 (High) and click Submit - it is 100% done instantly, and when I choose "View Content", there's no media file there, just the info.txt.
DV, iPhone, etc - you can see it recompressing frames, and when you view content, there's a media file there, too.
Any idea what could be going wrong with the H264 output?
Smoke 2012 SAP 1
NVIDIA FX 4000
David Jahns
Joint Editorial
Portland, OR
Brian Mulligan
Re: WireTap Central - not exporting h264 quicktimes
on Mar 13, 2012 at 8:02:50 pm
What res are your trying to export from and to? No issues here.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
David Jahns
on Mar 13, 2012 at 9:24:06 pm
working in 1080p23.98. Source material was ProRes 4444, color graded in Smoke, everything fully rendered and saved to Library - just trying to make a decent resolution H264 QT for clients to view on the web.
David Jahns
Joint Editorial
Portland, OR
David Jahns
on Mar 13, 2012 at 9:26:44 pm
just tried the same thing from a project with DPX source frames - same result.
David Jahns
Joint Editorial
Portland, OR
Grant Kay
on Mar 19, 2012 at 9:20:24 am
Hi David,
This is a total stab in the dark but is there any audio sources attached to the timelines you are trying to export as H264?
Just a thought.
Regards
Grant
Check out my Smoke blog at http://area.autodesk.com/blogs/discreetuk
Subscribe to my YouTube Channel - SMOKEHOWTOS
Follow me on Twitter - http://www.twitter.com/discreetuk
David Jahns
on Mar 23, 2012 at 1:09:24 am
yes, there is definitely audio on the sequences. the crazy thing is that the other formats work just fine. I guess I'll have to try my re-seller support, which has not been so impressive...
David Jahns
Joint Editorial
Portland, OR
David Jahns
on Apr 10, 2012 at 12:12:41 am
Strange - got tech support through reseller and then Autodesk. Encoding worked when running the commands in Terminal, but not from the web interface.
Tech Support was stumped, too - but the update to the latest version seems to have fixed everything.
David Jahns
Joint Editorial
Portland, OR
