Can anyone get animated gaussian blurs to come across FCP XML to smoke?
COW Forums : Autodesk Smoke
Roger Bolton
on Jan 16, 2012 at 12:00:16 pm
The wikihelp mentions that gaussian blurs should get transferred into an axis blur when you bring an XML in. I tried a simple XML with just one clip and a gaussian blur on it (with keyframes) and there is an axis effect created on the resulting timeline in Smoke, but no keyframes are set for the blur value.
Anyone get this to work?
CoreMelt V2 plugins
Grant Kay
Re: Can anyone get animated gaussian blurs to come across FCP XML to smoke?
on Jan 16, 2012 at 2:30:49 pm
Hey Roger,
If you expand the clip in the timeline, is there anything in the clip comments.
You could also ALT+CLICK in the clip for its information.
Regards
Grant
Check out my Smoke blog at http://area.autodesk.com/blogs/discreetuk
Subscribe to my YouTube Channel - SMOKEHOWTOS
Follow me on Twitter - http://www.twitter.com/discreetuk
Roger Bolton
on Jan 17, 2012 at 2:46:05 am
there is a comment "FCP Filter of type Gaussian Blur not supported, replaced by soft axis". However in the axis effect enabled on the track, there is no blur values or keyframes.
Grant Kay
on Jan 18, 2012 at 12:53:38 pm
Hi Roger,
That is correct. Smoke does not correctly know how to translate the values of the Blur so it adds a softFX axis to the clip so it can be blurred but the animation is not translated across.
Regards
Grant
