Color Warper Sluggish - more RAM? any other options?
COW Forums : Autodesk Smoke
David Jahns
on Jan 13, 2012 at 11:37:05 pm
Hi all.
I'm a Smoke newbie, and have a Smoke on Mac, running on a 12-core with Quadro 4000, 12 GB RAM, and the Avid Artist Color Panel. I'm quite happy with the performance I'm seeing so far, except when I'm in the Color Warper.
Smoke seems to responds rather sluggishly to both the Control Surface, and the pen/tablet input - the screen updates at 1-2 frames per second at best. I am constantly overshooting and having to dial the correction back.
(usually working with 1080p24, either DPX or ProRes 4x4)
Granted, I know it's not a dedicated grading system like a Resolve, but I was hoping it would at least be as good as Apple Color's realtime response to the color panel input.
So - is there anything that could help? more RAM? how much for HD work? 24? 48?
Or would the FX 4800 perform better?
Any other ideas to try?
(and Autodesk - if the 3 selective corrections could have the option to add a gmask - that would be extremely helpful!)
Thanks for any advice...
David Jahns
Joint Editorial
Portland, OR
Brian Mulligan
Re: Color Warper Sluggish - more RAM? any other options?
on Jan 14, 2012 at 2:12:05 am
Sounds like it could be a driver issue. also the 4000 has known issues with any os that is not 10.6.7
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Joel Osis
on Jan 14, 2012 at 3:10:25 am
I would also check to make sure you preview mode is set to "realtime" and not "preview fx", I think smoke on Mac defaults to preview fx on new projects
w: http://www.joelosis.com
e info@joelosis.com
Grant Kay
on Jan 16, 2012 at 10:38:35 am
I agree with Joel. I have had an Avid Artist Series panel in the past and when working interactively I had to switch from PREVIEWFX to REALTIME in the player.
With PREVIEWFX, the system is constantly caching so that you can preview your FX. In realtime mode, it throws the process on the CPU and gives instant feedback. The results are not cached but this should not be an issue.
Hope this helps.
Regards
Grant
Check out my Smoke blog at http://area.autodesk.com/blogs/discreetuk
Subscribe to my YouTube Channel - SMOKEHOWTOS
Follow me on Twitter - http://www.twitter.com/discreetuk
David Jahns
on Jan 18, 2012 at 4:22:21 am
YES - Switching from Preview FX to Realtime helped tremendously. Thanks, guys!
Much cheaper than 12 more GB of RAM. ;-)
David Jahns
Joint Editorial
Portland, OR
Adrian Lopez
on Feb 12, 2013 at 11:14:53 pm
I'm having the same problem.. where do I find this Preview setting. Just installed Smoke today, still learning the lay of the land...
