Deleting a clip from the timeline
COW Forums : Autodesk Smoke
Corinna Canek
on Jan 9, 2012 at 1:45:31 pm
I have a timeline with 3 videolayers. Now I want to delete something from the first video layer. Then I want the gap closed (I know that works with Ripple enabled), but then how can I achieve that the clips on the other layers move accordingly? Cause right now, only the clips from the first layer move over to close the gap...
robert coulin
Re: Deleting a clip from the timeline
on Jan 9, 2012 at 3:02:27 pm
hi,
you can shift+click the top layer (if the selection is on first), which will select the same duration on all layers - or CTRL+click individual elements (gaps)
you could also set in/out according to the element & extract the active tracks(layers
robert
robert coulin
http://www.dreamwalks.com
