how to create a freeze frame in batch?
COW Forums : Autodesk Smoke
Andriy Toloshnyy
on Dec 18, 2011 at 3:09:46 am
Hi everybody!
How would you create a freeze of a particular frame in batch to paint a clean plate?
And maybe someone would share some tips on creating and painting a clean plates also )))
Thank you!
rohan khokar
Re: how to create a freeze frame in batch?
on Dec 18, 2011 at 9:22:42 am
if u use sapphire plugins, the easiest way is to use S-Temporal> Get Frame and select the particular frame u wud like to freeze
Andriy Toloshnyy
on Dec 18, 2011 at 11:44:41 am
thanks for the tip, but maybe there is some plugin-free way of doing it using the native tools?
how would you deal with the clean plates in batch usually? creating and painting it at the desktop and then getting into?
Brian Mulligan
on Dec 18, 2011 at 4:06:45 pm
2012x1 has some still frame functions with new mix and time warp nodes.
You can also use Action to slip the frame you want and lock front.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Joel Osis
on Dec 19, 2011 at 10:46:59 am
Don't forget about the new functionality of the MUX node which allows you to choose the in and out and repeat start and end frame, I use this with batch paint if I am creating clean plates and then set my out point to one frame an cache my strokes, this dramatically speeds up render times
w: http://www.joelosis.com
e info@joelosis.com
Andriy Toloshnyy
on Jan 5, 2012 at 10:43:17 pm
Hi! Would be good to use it, but I cannot find this options in the MUX node.
It has just hide input and output connections buttons. Also cannot find it in the manual...
I'm working on 2012 sp2, is it ext1 specific?
Thank you!
Joel Osis
on Jan 17, 2012 at 1:49:18 am
I think it is exclusive to Ext1
e info@joelosis.com
toby aldridge
on Jan 24, 2012 at 12:23:06 pm
select the clip you wish to freeze , select BASIC and then click Lock frame on the frame you wish to freeze, this will turn this clip into a still frame.
