Changing lens flares
COW Forums : Autodesk Smoke
jake blackstone
on Dec 15, 2011 at 6:25:53 pm
When in Action, I use the lens flare. But if I want to use different flare from the default one, I use "load" and I can select a different flare from the presets. But the problem is when I do that, all my Action scene gets replaced by an empty scene with just the new flare. Any ideas how to just select different flare without losing everything?
Brian Mulligan
Re: Changing lens flares
on Dec 15, 2011 at 6:51:33 pm
Use the PRESETS node, it will defautl to 3D text, but you can toggle to Lens Flares. They will then Add to your scene.
If you want to use your way and LOAD.. then witch the blue pp up in the load menu from ALL to ADD Nodes+media
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
jake blackstone
on Dec 15, 2011 at 7:09:12 pm
That is exactly what I need.
Thank you.
