Autodesk smoke 2011 paint on sequence?
COW Forums : Autodesk Smoke
Barry Liu
on Dec 10, 2011 at 4:55:11 am
Hello!
I just installed Smoke 2011, I know, old copy.
I am trying to find the option to "Paint On Sequence" instead of just one frame.
I see in the smoke wire removal tutorial here: http://area.autodesk.com/flame-tutorials/exercise_wire_removal-4
It is done in Batch in the tutorial.
Does 2011 Smoke on Mac OSX not have Batch? Which means I cant access the "Paint On Sequence" with a paint node?
The paint effect I select doesnt seem to have it, maybe because it is considered a soft effect?
Please help.
robert coulin
Re: Autodesk smoke 2011 paint on sequence?
on Dec 14, 2011 at 8:40:51 pm
hi,
actually Paint in smoke on mac is a separate module - no softfx, as you mean.
there you have "Canvas", which paints directly on an individual frame,
or "graphics", which are vectors & can be rendered over the sequence
in "Canvas" you also have an "Autopaint > User" option, where you can record a paintstroke/s an render it over a defined duration (by a second timeline)
batch-paint is not available due to lack of batch ...
hth
robert
robert coulin
http://www.dreamwalks.com
