108050i project without kona card
COW Forums : Autodesk Smoke
Eduardo Lorente
on Oct 26, 2011 at 5:01:55 pm
Hello everyone
How I create in smoke 2012 for mac a 1080 50i project without a kona3 card? because this resolution does not exist when I starts smoke and create a project.
Thank you
chris north
Re: 108050i project without kona card
on Oct 27, 2011 at 10:47:09 am
1920x1080@50i is available as a CFG template when you create a new project. Is the template not available on your system?
Eduardo Lorente
on Oct 27, 2011 at 9:11:35 pm
Hello Chris.
No when I create a new project only have available the following resolutions:
pal.cfg ; ntsc.cfg ;,film_ntsc.cfg ; film.cfg ; 24p_ntsc.cfg; 24p_1920x180@5994i.cfg ;24p.cfg ;1920x1080@3000p.cfg ;1920x1080@2997.cfg; 1280x720@5000p.cfg and this is all.
No more resolutions but if I go to have a look to c:/usr/discreet/Smoke_2012.Sp3/cfg/
macosx-x86_64/template folder I found this template that I talk. (1920x1080@50i and many others like 1920x1080@50i )
I checked the smoke setup utility (in applications/autodesk/ Smoke 2012 SP3/utilties folder and I try to activate in preview tab the following resolutions 1920x1080@50i and other like 1920x1080@50i_free
but no way.
If these resolutions are into the templates folder,why smoke not shows to me when I create a new project?
I remember you that i havenĀ“t got an aja kona3 card.
Any help would be appreciated.
Thank you
