Smoke Crashes on XMl Import
COW Forums : Autodesk Smoke
Michael Ruiz
on Oct 21, 2011 at 5:05:00 pm
Hi Everyone
I'm new to Smoke and have an issue.
Im importing an xml from FCP and Smoke crashes in the library. I'm taking a class @ FXPHD and the first class is an easy xml import reading the source media.
As soon as I load the xml into the clip library Smoke crashes.
I know this is vague but any guidance on finding a solution would be helpful. I've already gone thru the system set up requirements and have a great machine built to Smoke requirements.
I'm wondering if it is a network configuration of some sort? Not sure... any help would be appreciated.
image attached at freeze point
3117_smokecrashpoint.jpg.zip
Thanks !
m i c h a e l
moody glasgow
Re: Smoke Crashes on XMl Import
on Oct 21, 2011 at 6:10:20 pm
I would check the XML. Most likely it is something inside the XML.
moody glasgow
smoke/flame
Michael Ruiz
on Oct 21, 2011 at 6:30:44 pm
Thanks Moody --
I tried but it's also any media clip I add freezes Smoke? Kind of frustrating trying to source the problem :)
Brian Mulligan
on Oct 22, 2011 at 2:35:36 am
I know you aren't dealing with red... But it might help.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
David Owen
on Oct 25, 2011 at 12:07:52 pm
I've had a simular problem with crashing on imports. If you have Qmaster running try turning it off. Worked for me.
D
Michael Ruiz
on Oct 26, 2011 at 4:40:35 am
Thanks David -- I'll give it a try and report back. I'm going to post a longer thread and hopefully figure it out.
Much appreciate the response !!
m i c h a e l
