frustrating hotkey problem
COW Forums : Autodesk Smoke
andi no
on Oct 10, 2011 at 4:49:55 am
Hi, i'm using 2012 on mac. I created a user based on FCP hotkey. For a new clean user, when loging into the smoke , quite fast... it only takes couple of seconds. Then as i customize my hotkey, make a lot of changes, finally i end up with problem : when loading this user, the loading time can take more than 3 to 5 minutes. So i have to wait that long before i got into the smoke desktop. If i start by creating a new fresh user, it's fast, no problem at all but then if i switch back to my custom user, i got the problem back.
If i create a new user and then copy the pref from my custom user then i got the same problem. If i create a fresh new user, then manually customize my hotkey one by one again, it will start to be very slow again when loading it.
I also tried to restart smoke or mac but still have the same problem.
So, why setting up my hotkey can drag me into this problem ???? what's the problem with the user setting?
© 2018 All Rights Reserved
