Smoke 2012 and Monsters GT problem
COW Forums : Autodesk Smoke
Lukasz Matkowski
on Sep 26, 2011 at 9:55:32 am
Hello, did anyone expierence problems using Monsters GT sparks with Smoke on mac 2012 ver? With valid license number I only see black screen. The same thing happens with "trial" version without license number. Anyone? Please?
Brian Mulligan
Re: Smoke 2012 and Monsters GT problem
on Sep 26, 2011 at 2:01:03 pm
Have you contacted Genarts? I don't even know anyone who uses those Sparks. Sapphire are the standard for IFFS.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Lukasz Matkowski
on Sep 26, 2011 at 2:36:45 pm
Yes I did and they try to fix this problem but I wanted to find out if enyone has the same problem. The Sapphire set, on the same machine works fine and I have no problem working with them...
Lukasz Matkowski
on Sep 27, 2011 at 6:19:55 pm
Thanks to Gary from GenArts, the problem was solved,
Thanks!!!
Will Percy
on Oct 4, 2011 at 7:21:15 am
How did you fix this? I have the same problem with the trial version, there is only black screen!
Lukasz Matkowski
on Oct 4, 2011 at 7:36:51 am
There was a problem with installation file and Genarts had to rebuild the installer. They did that and it works great :)
Once you download the new ones (from Genatrs web) it should work properly.
http://www.genarts.com/support/downloads/monsters-gt/autodesk
6.0 release 1a3 version
good luck :)
Lukasz
