Turning off Anti-Aliasing on individual layers
COW Forums : Autodesk Smoke
Alan Maiden
on Sep 14, 2011 at 9:08:21 am
I am trying to render an action but without anti aliasing on one of the layers. In previous versions you would set your anti-aliasing then go to the object tab of the layer you didn't want to add anti-aliasing to and de-select the filtering button. I can't find this as an option in 2012. Anyone able to steer me in the right direction or is it no longer possible!
Cheers
Brian Mulligan
Re: Turning off Anti-Aliasing on individual layers
on Sep 14, 2011 at 11:36:47 am
I think NEAREST is the same as Filtering off.
Brian Mulligan
Senior Editor - Autodesk Smoke
WTHR-TV Indianapolis,IN, USA
Twitter: @bkmeditor
Alan Maiden
on Sep 15, 2011 at 9:26:58 am
Thanks, not an obvious one to guess then!
