8 Channel Audio FILE output
COW Forums : Autodesk Smoke
Craig RussillRoy
on Sep 7, 2011 at 10:16:59 am
Ello Ello !
Ok having a issue exporting a QT from SMOKE Demo - End result i want is a 1920x1080 23.98 Uncompressed - 8 channels audio - got PCM audio set and send to Background process - it falls over on frame 1 all the time /..
Saved REC AREA to Database and have read write permissions on systems drives .... can you export multiAudio to a file from SMOKE ???
Cheers in advance
Adstream London, England
4 x Mac Pros, FCP7, 4 x Flip Factories, 35 x Rhozet Carbon Coders, Offices Globally
Grant Kay
Re: 8 Channel Audio FILE output
on Sep 7, 2011 at 1:37:12 pm
What is the error you get when it fails?
Regards
Grant
Check out my Smoke blog at http://area.autodesk.com/blogs/discreetuk
Subscribe to my YouTube Channel - CREATIVEFINISHING
Follow me on Twitter - http://www.twitter.com/discreetuk
Craig RussillRoy
on Sep 7, 2011 at 3:28:06 pm
Cheers Grant,
Can not read frame 1 - i noticed my Backburner Manager was red - tried restarted with no luck - Bounced the box and it is GREEN now but still no luck - I tried a old file with Stereo that i could make work before and that mentions cant read frame 9 - so it looks local somewhere - is there Logs anywhere so I can check ?
Thanks again - btw it should spit out multiTrack Quicktimes ?
Grant Kay
on Sep 8, 2011 at 8:38:01 am
It sounds like there might be configuration issue with your system.
Can you contact Autodesk Support or Post on the Smoke AREA forum?
Regards
Grant
