No audio output
COW Forums : Autodesk Smoke
Corinna Canek
No audio output
on Aug 25, 2011 at 1:20:26 pm
I can't get a sound out of Smoke.
I have an AJA KONA 3G (the settings should be right, because I'm getting audio out of FCP).
Are there any settings I have to change inside of smoke in order to hear something? I can see the audio in the RTW, so I know it's there...
Marc-André Ferguson
Re: No audio output
on Aug 26, 2011 at 12:47:02 pm
Did you check the Sound panel in your Mac's System Preferences?
The output should be set to the Kona, and your speakers connected to it's outputs.
Marc-André Ferguson
Smoke Industry Manager
Autodesk Media&Entertainment
Follow me on Twitter : @iluminance
Find out more about Smoke for Mac : autodesk.com/smokeformac
Corinna Canek
Re: No audio output
on Aug 30, 2011 at 8:58:56 am
Yes, everything is set to the Kona.
I also get the warning sounds from Smoke (like when I have to confirm something). It's just not playing back the audio...
Marc-André Ferguson
Re: No audio output
on Aug 30, 2011 at 5:20:41 pm
Sorry, my bad - should have checked with support first ;-)
The Sound System Preferences panel needs to be set this way:
In the Output tab, make sure the device selected for sound output is not the AJA card.
Select, for example, Internal Speakers, or Line Out.
In the Sound Effects tab, also make sure Play sound effects through is set to something other than AJA.
When you launch Smoke, it will grab hold of the card's driver and output properly.
Marc-André Ferguson
Jeff Dowd
Re: No audio output
on Mar 6, 2013 at 2:58:56 am
I've followed your settings but I still don't have any audio. I can fire up Final Cut and it plays audio just fine. Smoke has no out put to the audio monitors. I can see the modulation on screen but it ends there!
Jeff Dowd
