XML import -Resize soft effect
COW Forums : Autodesk Smoke
Hillary Knox
on Aug 20, 2011 at 3:05:47 pm
So this is probably pretty basic knowledge to everyone but me...
Whenever I import an XML it works great, but why is the Resize soft effect always on? It looks like everything is the proper size, but I don't understand why Resize is necessary. I read (well, skimmed) through the manual to see if there was any mention of Resize when importing an XML & I couldn't find anything. It's not actually causing me any problems, I just was curious why it's happening.
Thanks.
Tom Tortoriello
Re: XML import -Resize soft effect
on Aug 20, 2011 at 7:39:34 pm
Most likely because your Bit Depth (8, 10, 12, etc.) of the incoming clip does not match our Project settings. Just a guess. -TomT
Hillary Knox
on Aug 20, 2011 at 9:13:16 pm
You're right. That's exactly it. Or, at least, if that's not the whole story, it's definitely contributing to it.
