Inserting a clip in the timeline with multiple layers
COW Forums : Autodesk Smoke
Corinna Canek
on Aug 16, 2011 at 10:44:14 am
Hi there,
I have a timeline with a bunch of layers and now I have to insert a new clip into the timeline. How can I do that, so that ALL the clips in every layer move over?
Cause whenever I insert the clip, only the other clips in that layer in which I insert it, move over. All the others don't.
Please help!
Thanks!!
Frederic Warren
Re: Inserting a clip in the timeline with multiple layers
on Aug 16, 2011 at 8:50:33 pm
Hello Corinna,
You need to make sure to:
1. Have the Ripple button enabled
2. Have the Sync button enabled
3. Use the Insert command, not Overwrite.
The gotcha here is that the Sync button is also used for the Sync Group selection, so you might need to disable it afterward if you do not want to force the Group selection.
fred
fred
Corinna Canek
on Aug 17, 2011 at 7:10:13 am
Ah :) Thanks so much, that really helped :)
