Standard Conversion in Smoke on MAC
COW Forums : Autodesk Smoke
Craig RussillRoy
on Jul 28, 2011 at 11:23:02 am
THis goes out to Moody and Grant,
Guys can oyu do a tutorial for Smoke on MAC on how to do standard conversion on a MAC ?
We get in 23.98 and need to goto 25 / 29.97 and 25 -> 29.97 and reverse
how do you do it ?
Cheers in advance !!
using demo 2012
Adstream
London, England
Mac Pro - 8gig ram - FCS 3 - CS4 - Cinema 4D, Flip Factory, Rhozet, Episode
Joel Osis
Re: Standard Conversion in Smoke on MAC
on Jul 29, 2011 at 2:34:41 am
the 2 methods I use are
1. create a color source at the desired resolution,
drop this onto the record area, then drop your footage into this timeline, smoke will automatically add a timewarp to convert your footage to the desired framerate
2. from the edit desk select the timecode menu then Convert rate,
select the desired frame rate then select the clip
my preference is option 1 as you can play with blending in the timewarper , where option 2 is linear and has no controls
w: http://www.joelosis.com
e info@joelosis.com
moody glasgow
on Jul 29, 2011 at 2:10:41 pm
I generally use method one for framerate conversion like this.
moody glasgow
smoke/flame
Grant Kay
on Jul 29, 2011 at 9:01:17 am
Hi Craig,
I agree with Joel's number 1 method...
Mathematically going from 23.976 (24) to 25 or 29.97 is quite simple so this method should be fine.
Going from 25 to 29.97 might be a bit more tricky if there are fields involved which might involve some de-interlacing, timewarping and re-interlacing as not to get frames interlacing incorrectly. But If it's all progressive that method 1 should work more or less the same.
Give it a go and let us know how you get on.
Regards
Grant
Check out my Smoke blog at http://area.autodesk.com/blogs/discreetuk
Subscribe to my YouTube Channel - CREATIVEFINISHING
Follow me on Twitter - http://www.twitter.com/discreetuk
Craig RussillRoy
on Jul 29, 2011 at 7:59:57 pm
Thanks a bunch guys - testing testing testing !!!
Adstream
London, England
Tai Tran
on Jan 23, 2012 at 11:23:27 pm
Hey Craig,
were you happy with the standards conversions on smoke? Mike C mentioned i should look into it for up/downscaling
janhavi padhye
on Nov 14, 2013 at 7:00:08 am
I tried it but didnt work
