How to connect media to my XML in SMOKE
COW Forums : Autodesk Smoke
Josh Sutherland
on Jun 16, 2011 at 8:56:26 pm
Hey Guys,
I'm having some problems linking the media to my XML in smoke, I click import xml, navigate to it in the network, load it, the exit recapture, and the unlinked xml is in my library....
I guess you are supposed to link it during the recapture screen, but i cant figure out how. I can see my clips with time code in there...but I dont know what to click.
Can someone walk me through this please?
Grant Kay
Re: How to connect media to my XML in SMOKE
on Jun 16, 2011 at 10:22:08 pm
Hi Josh,
I suspect you are trying to import the XML using a legacy method in Smoke.
The new correct way is through drag and drop using the gateway...
I am in the process of publish videos how to do this in Autodesk Smoke 2012 for AAF and XML.
I will post here and other places when i have published these videos.
In the meantime you can watch this video about conforming XMLs with Quicktime media in v2011 of Smoke which is more or less the same... http://area.autodesk.com/blogs/discreetuk/workflow_xml_quicktime_conforming...
Good luck and I hope it works out for you.
Regards
Grant
Check out my Smoke blog at http://area.autodesk.com/blogs/discreetuk
Subscribe to my YouTube Channel - CREATIVEFINISHING
Follow me on Twitter - http://www.twitter.com/discreetuk
