Smoke 2011 Read Only mode folder Issue
COW Forums : Autodesk Smoke
José Pombo
on Jun 8, 2011 at 9:56:07 am
I have a problem in Smoke 2011, my folder is in read only mode, how can i change it?
Have a nice day,
José Pombo.
Rob Ufer
Re: Smoke 2011 Read Only mode folder Issue
on Jun 14, 2011 at 6:25:59 pm
Hey there,
You'll need to check if the library in question is being locked by a current process... like a burn node or another user.
If you are SURE no other system process is using the library, you can simply delete the lock file.
To find the lock file:
Open a shell, su.
cd /usr/discreet/clip
find . -name '*lock'
---This is show all locked libraries.
find the locked file in question,
rm (locked file name) <-do not add parentheses.
Good luck :)
Rob FX
scott Jenal
on Jul 8, 2011 at 10:51:18 am
Where would I find the 'SHELL'?
sorry only new to mac and autodesk smoke.
Scotty
Rob Ufer
on Jul 8, 2011 at 4:57:33 pm
on a mac, a shell is a window opened in the app called Terminal. To access the root level of your system, open a shell in Terminal and type sudo su, then it will ask for a password.
Rob FX
