analog component enable on Smoke 2012 ??
COW Forums : Autodesk Smoke
Anhtu Vu
on May 19, 2011 at 11:54:21 pm
Anyone knows if the analog component of the Kona 3 is finally working on Smoke 2012 ?? Thanks
Grant Kay
Re: analog component enable on Smoke 2012 ??
on May 23, 2011 at 9:29:06 am
The component analogue outputs of the AJA bob are not supported.
Smoke has always only used the SDI outputs from SD and HD outputting.
Regards
Grant
Check out my Flame and Smoke blog at http://area.autodesk.com/blogs/discreetuk
