Smoke on Mac ProRez issues
COW Forums : Autodesk Smoke
Adam Corey
on May 16, 2011 at 11:35:56 pm
One of my Smoke on Mac 2011 systems is unable to read prorez files when doing either a soft or hard import. It can read DVCPro and other codecs, but is unable to read prorez. The other identical system is not having any problems with Prorez. Any known issues?
Adam Corey
DC Collective
Design - Edit - Create
http://www.dccollective.tv
Gregory Qualls
Re: Smoke on Mac ProRez issues
on May 17, 2011 at 12:55:18 pm
Is Fcp installed on this system?
Adam Corey
on May 17, 2011 at 3:02:55 pm
yes FCP Studio is installed on both systems as well as cs5
Adam Corey
DC Collective
Gregory Qualls
on May 17, 2011 at 8:13:16 pm
Have you tried importing a different ProRez clip, maybe file is corrupt. If so try reinstalling smoke.
Brian Buongiorno
on May 29, 2011 at 1:12:44 am
What version of Mac OS are you running? I had this problem once I updated to 10.6.7. I had to reinstall 10.6.5 before I got it working again. Also, it helps to use a manually assigned IP address on your network settings. Using DHCP can cause this problem as well.
Brian Buongiorno
tonevisuals.com
