Alignment in Source Area
COW Forums : Autodesk Smoke
Diana Yuen
on May 12, 2011 at 6:42:28 am
Is there any shortcut that I can auto align the clips in source area? it is quite messy when import the footages into the source area . thanks!
Grant Kay
Re: Alignment in Source Area
on May 12, 2011 at 8:22:26 am
Yes you can.
To the left of the interface you will see the blue pop up button that could be labelled as SOURCE AREA/EDIT SYNC/EDITING/EFFECTS/FILTER SELECT.
Switch it to SOURCE AREA mode and make sure it is active (you will see the blue LED by clicking on it)
You should than see the source area menus.
Click the SELECT ALL button
Three buttons to the right of the SELECT ALL button you will see another button labelled either STACK/TILE/CASCASE.
Choose the TILE mode and all the selected clips will title on the desktop.
Hope this helps.
Check out my Flame and Smoke blog at
© 2018 All Rights Reserved
